'57 Brake Linings/Fluid - NCRS Discussion Boards
  • Bob A.
    • April 1, 2003
    • 172
    Were the original 1957 Brake Linings (front and rear) Riveted or Bonded to the Shoes?
    What type of Brake Fluid should be used, Silicone or otherwise (DOT 4 or DOT 5)?
    Thanks!
    Bob
    Re: '57 Brake Linings/Fluid
    Bob -
    The original linings were bonded to the shoes - functionally, it makes no difference whether they're bonded or riveted. Fluid selection is always an exciting discussion topic - you'll find lots of material in the archives; personally, I prefer DOT3/4 glycol-based conventional fluid.
    • Wayne K.
      • December 1, 1999
      • 1030
      Bob,
      If your system has conventional brake fluid in it them use DOT-3 or 4. Dot-5 is silcone and should not be mixed with conventional fluids. If your system currently has DOT-5 silicone then that is your only choice.
      Wayne
