Racing Fuel Ratio - NCRS Discussion Boards
Racing Fuel Ratio
  • Tom M.
    • August 31, 2000
    • 231
    Racing Fuel Ratio
    The members that mix 93 octane pump gas and 110 racing fuel what Ratio do you mix it at, and do you ever use it straight? A friend that runs a speed shop just gave me 10 gallons to try.
    Tom McCAbe
  • Chris H.
    • April 1, 2000
    • 837
    Re: Racing Fuel Ratio
    Mix 'till the pinging goes away. Or advance your timing to take advantage of the fuel. I personally use a few gallons per tank.
    • Rick A.
      • July 31, 2002
      • 2147
      Tom,
      Right now, since I just rebuilt "LADY" I am running pure unadulterated 110! Once I get a couple of hundred miles on her I will change it to 1 gallon of 110 to every 4 gallons of 93 - that is what I was told to start with for a mixture on my 1963 Z06 fuellie (LADY)
      Rick Aleshire
      2016 Ebony C7R Z06 "ROSA"
      • John L.
        • 409
        Tom - I have a 66 427/425 11:1 Timing 12 degrees btdc Echelin 1810 Vacuum can - I use anywhere from a 50/50 mix to mix of 5 gallons racing to 7 gallons 93 octane. No pinging - no dieseling at shut off. Car runs great.
        • Tom M.
          • August 31, 2000
          • 231
          Thanks to all, I will start with 50/50 first and go from there, is $310 a good price for a whole barrel?
          Thanks for the responses,
          Tom McCabe
          • Clem Z.
            • January 1, 2006
            • 9427
            for Racing Fuel Ratio to pump gas go to
            www.idavette.net/hib/fuel/page2.htm
