1960 Antenna Mounting location - NCRS Discussion Boards
  • Peter K.
    • January 1, 1999
    • 117
    During my restoration I was forced to replace the left side upper rear fender, as my original was damged beyond repair. The new part does not have a hole drilled for the antenna mounting. Can anybody give me a dimension from the rear of the taillight housing area in the fiberglass to the center of the mounting hole?? and the diameter of the hole?
    Thanks again!!
    Peter
  • Joe Maulsby
    Re: 1960 Antenna Mounting location
    If you can wait until the weekend, I will be glad to measure the location for you and get back with you. Maybe someone will respond befor then.
    • Al C.
      • July 31, 1999
      • 274
      On my '58, the hole is centered 3.5 inches ahead of the forward edge of the taillight housing, and on the center line of the taillight. ... Al '58 245hp
      • joe utz
        on my 1960 the antenna is also 3.5 inch forward of the front edge of the chrome of the rear tail light.
        joe
