C1 Parking/Tail Light Bulbs - NCRS Discussion Boards
  • Jim Sloan
    Found out a few days ago that the correct light bulb according to the owners manual and the Corvette Servicing Guide for a 55-60 front parking/signal light and the rear tail/signal light is #1034. When I removed mine from my 60 there were a combination of bulbs #1157 and #2057 installed. These were probably put in around 15 years ago, as I have not touched these bulbs since I have had the car. I understand that #1034, #1057 and #2057 will all fit in the socket and look almost identical. My question is what is the brighter bulb? Did #1057 and #2057 bulbs come along later and are they the replacement for the #1034? I would like to change mine to the correct 1034 but if the 1057 and 2057 is brighter, maybe that would be the better thing to do. Any opinions on what anyone else has done with this bulb issue? I understand that all three bulbs are still available.
  • Brian M.
    • February 1, 1997
    • 1840
    Re: C1 Parking/Tail Light Bulbs
    First off they are called Lamps NOT bulbs. A good friend has been beating this into my head and I think I'm catching on. Check out WWW.Lamptech.com
    • Gene B.
      • May 31, 1990
      • 144
      The 1157 and 2057 lamps are brighter, however the brighter the lamps the more resistance is applied to the flasher, resulting in the signal light flashing too quickly. I would use the 1034 lamp.
