Front crossbember dent remover tool. - NCRS Discussion Boards
  • Terry F.
    • September 30, 1992
    • 2061
    Hi, some may remember my previous post regarding the dents commonly found in the front crossbembers of corvettes from 1963 to 1982.
    Anyways, it is my understanding that the center of the front crossmember on corvettes from 63 to 82 is identical. I would like to hear from as many people as possible that are familiar with that section of the car and would know if it is essentially the same. I have been told by one knowledgable person that they are essentiall the same but I want to here from others if possible.
    I will be able to provide pictures of the final product soon if people are interested. Thanks in advance, Terry
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: Front crossbember dent remover tool.
    There are some differences on the top side for dampner clearances, but I think the bottom side is the same....
    tc
    • Terry F.
      • 2061
      Nice to know. I am only concerned about the bottom side. Thanks, Terry
      • Tom S.
        • March 1, 2004
        • 1087
        I for one will be interested in your tool for the crossmember when you get it perfected. Mine is dented somewhat so I could use it. Thanks Tom
        • Craig S.
          • June 30, 1997
          • 2471
          Terry - I am waiting too....sounds interesting....Craig
          • Warren L.
            • February 1, 1990
            • 85
            nother way, surgery requireda
            cut the dent section out, mig back in a correctly shaped piece of metal, stronger grade or a bit thicker.
            Warren
              Replacement panels are a Paragon catalog item.... *NM*
              • Joe C.
                • August 31, 1999
                • 4598
                What's A Crossbember?
                Is it like a widget? A finnigan pin? A kinniflin pin?
                • Terry F.
                  • 2061
                  (Message Deleted by Poster)
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    Re: What's A Crossbember?
                    that is a NCRS member when he is docked points for incorrect parts on his pride and joy.
                    • Terry F.
                      • 2061
                      Tool is for real and the machine shop will finish a small run of them next monday. It is a little nerve racking because if they don't build it right, I will have a garage full (34) and they will be useless to anyone.
                      I have heard that paragon has a replacement part for that section but I am not into cutting my frame up and welding upside down on my back. It gets pretty scary welding on a frame with the body still on it. There is typically a little grease in the crossmember and it will burn nicely and would love to start the whole car on fire. Body off would be much easier but not everyone is in that situation and not eveyone can use a mig welder (I can't).
                      What does Paragon sell that section for? Anybody know?
                      My tool works both ways, with or without the car on the body. I think that people would generally want to salvage the original section of the frame vs cutting it out. My tool can be used by people with different degrees of ability. I will let you all decide for yourself soon. I hope you are pleased with it. I would appreciate your honest feedback too. If people want them, I will keep making them, if not, we all know the answere to that one.
                      This is the first time I have ever ventured to do something like this. I hope it works out for us all. Best regards, Terry
                      • Terry F.
                        • 2061
                        Re: What's A Crossmember?
                        Cross"b"ember, crossmember now I get the joke. Best regards, Terry
                        • Joe C.
                          • August 31, 1999
                          • 4598
                          Terry:
                          Chrissakes, is THAT what that is?
                          Joe
                          BTW: I started having clutch problems right after I changed to a different bellhammer.
                          • Terry F.
                            • 2061
                            Joe, may wife scolded me for my response. I think it was a little too over the top. I am not a social butterfly. If my comments seem crude, I appologize if they offend. I enjoy the conversation. Thanks, Terry
                            • Paul O.
                              • August 31, 1990
                              • 1716
                              Terry I would be interested in one of your tools. Paul#18046
