82 ECM - NCRS Discussion Boards
82 ECM
  • Isaly Szetela
    82 ECM
    Any suggestions about where to find an ECM for a 1982 Corvette? The Vette has a 350 automatic. Any help would be greatly appreciated.
    • 43239
    Re: 82 ECM
    Isaly-----
    If it's an 82, I hope that it's got a 350 with automatic; that's the only way that ANY 1982 Corvette was ever originally built.
    Anyway, the part you need, GM #1225550, is GM-discontinued. However, it may still be available through Delco dealers under that number. Otherwise, try BBB Automotive at www.a-1injectors.com. They can sell you a re-manufactured example of the GM #1225550 (the GM part was a remanufactured piece, too).
    • William C.
      • May 31, 1975
      • 6037
      Re: 82 ECM
      I believe the '82 Camaro/firebird crossfire engine ECM will work as long as you use the Corvette cal PROM.
      Bill Clupper #618
        • 43239
        Re: 82 ECM
        Bill-----
        Yes, the 1982 F-body ECM is the same as 1982 Corvette.
