Passenger Side Mirrors on a Mid Year - NCRS Discussion Boards
  • Tom B.
    • February 1, 1994
    • 779
    Doug,
    The information you gave is very appropriate and timely. I hope you have asked Jerry for a copy of the article, as it may help if someone (like me) starts referring to it, and (here I go), in that article I am not able to find much, if any, reference to coolant under pressure or increased boiling point of coolant. I did look through what little information I had for that and realized my "burner" example was not an appropriate comparison, because what you said, the benefit of the pressure is to increase the boiling point of the coolant. Much of what is in the article raises some questions (to me) as to why some (or much) other information isn't in the article.
    It also states that the use of an "optional" restrictor (optional in the sense that the use of a thermostat is HIGHLY recommended) is to relieve the pressure in the radiator because of the cap. It doesn't go on to mention other variables (such as radiator coolant flow) that is affected. And I was curious as to why they just didn't recommend using a higher pressure cap instead. Your information answers the question I was beginning to have: if the pressure in the block could be localized or separated from the radiator, as they were implying. From what you're telling me, it can't, since it's a closed system and flow in/out of the pump has to be equal.
    I'm becoming more convinced that using a restrictor is an inexpensive way of increasing pressure as well as reducing flow in the entire system. The benefits are the raised coolant boiling point and the enhanced time for heat transfer in the entire system. If I'm not getting this out of your information Doug, maybe you could help re-paraphrase some things for me. Thanks. Tom #24014
  • Bob Ivey
    Was a passenger side mirror ever a documented dealer installed option on a mid year. I put one on my 64 at my wife's request, but not sure this was ever an option. Thanks
    Bob
      • 15684
      Re: Passenger Side Mirrors on a Mid Year
      "Dealer installed options" don't count unless they were an official Chevrolet accessory - a tissue dispenser, toolkit, and fire exstinguisher as I recall, but I suspect that NCRS would deduct since these were not factory options. The dealer could paint the car purple with red flames as could an owner.
      There was never a mid year RH mirror available as a factory option, but other owners have reported having the dealer install one or installing one themselves.
      However a RH mirror shows up it is considered a modification.
      • David Van Weele
        I recall judging a 1964 at Cypress Gardens in 1982 with just such a mirror. The owner claimed it came that way from the factory, his father was a Chevy dealer in South FL. A letter from Chevy was produced saying they installed the mirror. He also had running bourbon and soda installed under the dash. We deducted for the mirror and also took off operation points since the drink dispenser did not work, we also deducted for the holes in the dash. I am not making this up!
          • 15684
          "running bourbon and soda"???
          Can you expand on this, Dave? I take it he had some sort of working bar installed under the dash(?). Has anyone discussed this with The Rev.?
          • Dale Pearman
            Tasteful Enthusiasts
            which automatically precludes bourbon and (ugh) soda drinkers, will have their sterling silver flasks of Beefeater safely tucked away inside their togs and sequestered in the boot! This practice thereby prevents point deductions. (and DUIs)
            The Rev.
            • David Van Weele
              Re: "running bourbon and soda"???
              Duke ..... The bar was there but it did not work so therefore the deduct for operation. I did not get into the actual details since I was one of the judges for exterior. I am trying to remember the owners name, he was well known in the early '80s, at least in Fla.
