1980 rear wheel bearings - NCRS Discussion Boards
  • Finn
    Anyone able to help me with the part # on rear wheel bearings (inner and outer), races and seals? Need the producers # to be able to get hold of the bearings here in Norway.
    • 43239
    Re: 1980 rear wheel bearings
    Finn-----
    The original and current GM part numbers for the bearing assembly (bearing and bearing cup packaged together) are as follows:
    bearings:
    outer-- GM #7450700; currently GM #457052 (aka "S8" and Timken # LM48548/LM48510
    inner----GM #7451202; currently GM #9417784 (Timken # M86649/M86610)
    seals:
    outer--GM #3794006; currently GM #14079472; National #5113; CR #19803
    inner--GM #3794002; currently GM #12304213; National #91785
    • Finn F Lerfald
      Thank you Joe, saved my day :-)
