4 Speed shifter - NCRS Discussion Boards
4 Speed shifter
  • Robert V.
    • July 31, 2000
    • 84
    4 Speed shifter
    What holds the reverse lock out rod in the T-handle? Mine keeps slipping out and falling thru and I think that is the problem with why I am having shifting problems? Could it be worn out?
  • Jean C.
    • June 30, 2003
    • 688
    Re: 4 Speed shifter
    If you have an original type shifter, the lock-out rod is held in by a set screw with an Allen head. If you have an aftermarket shifter, the rod is likely cut and bent a little to hold it in the T-handle.
    Best regards,
    Charlie
