Install lower and upper dip stick tubes - small bl - NCRS Discussion Boards
  • Scott G.
    • August 31, 1984
    • 132
    I am in the process of installing new lower and upper dip stick tubes in my 66 L79. The press of the lower tube is very tight (top flared section) and I can not get it installed. Is there a trick to get these pressed in?
  • Tom P.
    • April 1, 1980
    • 1815
    Re: Install lower and upper dip stick tubes - smal
    I use a bolt about 3in long 3/8 and a small hammer to drive in the lower tube. Basically the same with the upper tube, but a 5/16 bolt about 1in long.
    • Al C.
      • July 31, 1999
      • 274
      This may be a good time to ask, "how far above the block outer surface should the top of the upper tube be (measured along the tube)"? Reason, i jsut did an oil & filter change and 6 new quarts is still below Add on the dipstick.
      ... Al '58 245hp
