Stamping on 70 trans and resr - NCRS Discussion Boards
  • Dennis Voiro
    Can anyone help me identify the following stampings from a 70 Coupe I'm buying?
    Trans POR31A
    Rear 2CAM11970 Not totally sure about this, it was hard to read.
    Where is the VIN stamped on the rear, I didn't see it near this stamping.
    Side Glass AS2 VV DOT 15 M74
    Windshield AS-1-83-66-55M 714GM
    DV
  • Donald T.
    • September 30, 2002
    • 1319
    Re: Stamping on 70 trans and resr
    Tranny. P=Muncie 4 speed. O=1970. The following letter represents the month, but can't be R. If it is actually a B then it would be February. 31 is 31st day of the month. A = 2.52:1 wide ratio.
    Rear. CAM is model year 1970 3.36 posi. 11 would be November and next two would be the day - can't be 97 so you will have to recheck. Last letter should be E for Eaton plant tor W for Warrent plant. VIN is not stamped on the rear.
    • Dennis Voiro
      Re: Stamping on 70 trans and rear
      Thanks for the help, I will try to recheck the numbers.
      • Chuck S.
        • April 1, 1992
        • 4668
        Dennis, the glass codes you have given us are not the important ones. Somewhere near the LOF logo there will be a two letter date code; using that and your car's build date, you can tell if the glass is original or replaced.
          • 15606
          Dennis,
          As a matter of fact the transmission build stamp CAN be an R = October.
          The manual transmission date stamps only follow the A=January, B=February, up to E=May. After that the letters for the month jump a lot.
          The answers to these, and other stamped and cast number and date information is in the 1970-1972 Technical Information Manual and Judging Guide (TIM&JG). Get ready for the shameless plug....Available from the NCRS store. Just a mouse click away from the button at the top of this page.
          • Jim T.
            • March 1, 1993
            • 5351
            Does the owner have the protect-0-plate for the car?
