Bad Shimmy on Front End - NCRS Discussion Boards
  • Edward D. Reich
    1960. Would anyone know the reason for a bad shaking of both tires, (seems to be side to side) once in a while if I hit some type of a bump around 35 to whatever. I am still using bias tires. I had a mechanic look at the front end and couldn't seem to find anything. He thought one tire was out of balanced, but that was it. I mean it really shakes pretty good where I have to hit the brakes to settle the shaking.
    Ed Reich. ( Florida )
  • Chuck R.
    • April 30, 1999
    • 1434
    Re: Sounds like a loose joint somewhere
    or a sloppy steering box.
    If it were up and down, I'd be more inclinde to think tires out of round or out of balance.
    Steering linkages should be closely watched with the full weight of the car on the suspension system and the steering wheel turned back and forth.
    Same goes with the steering box, pitman arm and mounting hardware to the frame.
    Your should probably then move to raising the car and placing a long bar under each tire and flex it up and down to double check the upper and lower ball joints.
    Do you have power steering or a steering damper?
    I'm sure you have done most if not all of these checks, but there's not alot under the front end that can produce a side to side rocking action through the steering wheel.
    One more "out there" possibility, loose wheel bearings?
    Ok I'm done. Hope you nail it,
    Chuck
    • Roy B.
      • February 1, 1975
      • 7044
      Re: Bad Shimmy on Front End
      You said it looked OK looking under the Corvette. Then I would check to see if the DRAG LINK is worn and lost it's tension . It's the main component between the steering box and all other parts that many people over look.
      • Dave F.
        • December 1, 2003
        • 508
        Sounds like ball joints to me.
        • Louis F.
          • September 30, 1991
          • 132
          I had a similar experience and could never fiqure it out. Then one day i was driving and one of the front tires blew out.When i stopped i noticed that the tire had "peeled"almost like an apple. There were large pieces if the treaded part of the tire on the street.I put two new tires on and never had the problem again.Tire store told me i probably had defective tires.The tires were 3to 4 years old with plenty of thread.Hope this helps you out.
          • Michael D.
            • February 1, 1978
            • 159
            Possibly tie-rod ends, idler or pitman arm, maybe a steering box problem. Hope you get it worked out before driving to far. Have the front end checked out.
            Mike D #1787
            • John M.
              • January 1, 1998
              • 813
              I've had this problem myself but in a later year car and it was the idler arm.
              • Mike E.
                • February 28, 1975
                • 5139
                Interesting thought--since it's a 60 and has kingpins and no ball joints!
                • Dave F.
                  • December 1, 2003
                  • 508
                  and that's why I own a '68 - Chuckster too!
                  and Chuck Rice swore it had ball joints !! Still sounds like bad ball joints. I'll go back under my rock....
                  • Terry D.
                    • May 31, 1987
                    • 2696
                    Dave
                    No ball joints on C1's, they have kingpins! How's the car coming?
                    Terry Deusterman
                    • Terry D.
                      • May 31, 1987
                      • 2696
                      Re: Bad Shimmy, Check Wheel Bearings Too *NM*
                      • Dave F.
                        • December 1, 2003
                        • 508
                        No ball joints - kingpins!
                        Got it! I thought everybody knew that inside every kingpin is a bad ball joint bustin' to get out. Car's coming along Terry....almost ready to fire her up!
                        • Chuck R.
                          • April 30, 1999
                          • 1434
                          Re: I guess I should say OOPs here huh?
                          What can I tell ya, after looking at this 68 for four years everything looks C-3ish to me
                          Sorry for the mis-leading statement there Ed.
                          Chuck
