'64 Brake Drums - NCRS Discussion Boards
'64 Brake Drums
  • Randy Adams
    '64 Brake Drums
    I am replacing all of my brake components (springs etc.) along with my brake drums. Does it make a difference about the spring around my front drums. I can't find anyone that sells drums with the spring groove in them. I can't find mention of it anywhere. Many thanks.
    • 43239
    Re: '64 Brake Drums
    Randy-----
    The purpose of the circumferential springs was, supposedly, to reduce brake "noise" (squeal). Just how effective they were at this is questionable. From a functional perspective, you don't need these springs. However, for NCRS/NCCB judging, the springs may have some benefit. So, if the latter is important for you, then you can obtain the springs and install them for judged events; perhaps the judges will not notice that the spring grooves are missing from the drums.
    • Randy Adams
      Re: '64 Brake Drums
      Thanks Joe, I hadn't thought of that.
        • 15695
        Re: '64 Brake Drums
        Ditto what Joe said about function. The springs cannot be seen in normal judging configuration. It MIGHT be possible to run your hand between the wheel and drum to determine if the springs are there "by feel", but I've never seen this done, and there is nothing in the JG about the drum "anti-squeak springs."
        • Randy Adams
          Re: '64 Brake Drums
          Thanks Duke, I couldn't find anything either that's why I brought my question to you Masters. Thanks again.
          Randy
