intake bolting C2 - NCRS Discussion Boards
intake bolting C2
  • Joseph K.
    • March 1, 1980
    • 168
    intake bolting C2
    Can anyone tell me if there is a sequence to bolting on a aluminum intake and what the proper torque for the bolts would be when installing. Thanks in advance.......Kirby
    • 43239
    Re: intake bolting C2
    Kirby-----
    There definitel is a sequence for torquing the intake manifold bolts. You will find a diagram with the sequence in your Chevrolet or Corvette Service Manual and you will also find it in many Chevrolet engine books, GM-published and otherwise.
    The intake manifold bolt torque 30 lb/ft for both big blocks and small blocks.
    • Bob R.
      • June 30, 2002
      • 1595
      I believe I saw a shetch in my shop manual which showed installing the center two bolts on each side then the outer bolts. Tighten in the same order working your way around the manifold.
