for john hinckley re corvette enthusiast - NCRS Discussion Boards
  • Werner R.
    • March 3, 2008
    • 184
    john
    the article talks about valve lash on a sb engine. can you suggest the procedure for cold adjustment of the l-72 bb engine?? i do not want to do this to a hot running engine, if possible.
    best
    werner
  • Chas Kingston
      Re: for john hinckley re corvette enthusiast
      Werner -
      The issues discussed in the article only apply to small-blocks with stock stamped rockers; neither the procedure for determining actual stock rocker ratio (and its rate of change with lift) nor the tedious cam lift/crank angle diagram measurement have been done on any big-blocks.
        • 15680
        I'll make you a deal Werner. You measure your OE rockers for their ratio behavior from the lash point to peak lift and I'll tell you the secret of how adjust the valves cold.
        • Werner R.
          • March 3, 2008
          • 184
          duke
          that sounds more than fair. i'll do my best to measure them.
          best werner
