C1 Window Post Tabs - NCRS Discussion Boards
C1 Window Post Tabs
  • Steve Westphal
    C1 Window Post Tabs
    As I get ready to paint and chrome my '56, I am curious about the "infamous" broken tabs on the window posts. Since I haven't disassembled it yet, I do not know what shape they are in. Is there any method of removing them that will spare the tabs in the event that they aren't broken?
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 Window Post Tabs
    Using a rubber mallet remove it evenly , don't pry it from the top area or bottom.
    • Calvin M.
      • August 31, 2000
      • 117
      Steve, I just lifted the complete windshield assembly from my '57 and had no problem with the tabs. I think most are broken when the assembly is rocked back and forth to break the seal. Try to go straight up.
      • Richard E.
        • November 1, 1976
        • 200
        Cal - Likewise on my 62 recently. You need to be equally careful on re-install and not over tighten those tab studs, AND make sure that the rubber fill strip(s) under each post are there as required. Regards, Dick
        • Mike E.
          • February 28, 1975
          • 5138
          Tabs are SELDOM broken by removal/installation of windshieldframe--they are almost always broken by a shrunken soft top being clamped down trying to make it stretch and clamp both on the windshield header and on the deck lid.
