NEED HELP WITH DRIVERS MIRROR LOCATION - NCRS Discussion Boards
  • Sheldon S.
    • March 1, 1999
    • 477
    I currently have my 65 coupe at the body shop getting ready to paint and the drivers door mirror had been taken off previously. I am trying to relocate the mirror but can't find any measurement for locating it on the door. I have searched the Assembly manual but nothing. Can anyone help with this. Thanks Sheldon
  • Mark J.
    • March 1, 1996
    • 254
    Re: NEED HELP WITH DRIVERS MIRROR LOCATION
    My '66 AIM shows a metal mounting plate riveted to the inside of the door skin. Can you see the plate?
    Mark
    • Sheldon S.
      • March 1, 1999
      • 477
      Plate is missing from door. Have new one to put on but need location. AIM shows the parts but does not give measurements. Sheldon
      • Karl Bugman
        Here's some info...
        This info is from a '67 Convertible door. I believe it will be the same for yours - hopefully someone will correct me if I'm wrong.
        On mine, the front mounting hole looks to be 14 3/4" back from the leading edge of the door at the body line, measured along the body line. Both holes are 7 1/2" up from the body line measured with flexible tape tight on the curve of the body. I'm refering to the screw holes not the rivet holes. Good use for a paper template. Hope that helps. -Karl
        • Sheldon S.
          • March 1, 1999
          • 477
          Re: Here's some info...
          THANKS KARL.
