c2 66 gear shift lever question - NCRS Discussion Boards
  • Larry Rosamond
    I've got the shift lever out with the intention of sending out for rechoming and see that cylindrical upper portion is "loose". Evidently, there is a pin which attaches the 2 pieces of the shift lever under a welded plug. What is the best or correct method to repair this attaching point or should I just rechome as it is. Do I drill the plug and reweld or can I tack weld 2-3 places at the mating surface of the 2 pieces?
    Thanks as always for everyone's assistance.
  • Joe R.
    • July 31, 1976
    • 4551
    Re: c2 66 gear shift lever question
    Larry,
    Volunteer Vette in Knoxville, Tn. is the source for mid year shifters, levers etc. The shifter shaft lists for $109.00 and is new. No welding or chroming needed. Contact them at 1 865 521-9100.
    JR
    • Joe R.
      • July 31, 1976
      • 4551
      Larry,
      JR
