Re: Calling Mr. Cosworth Vega
I have done a rod bearing load calculation through 720 degrees of rotation - the full four stroke cycle - for a high revving engine at maximum design revs.
Just wondering - has anyone else ever done this? If not I can tell you that it doesn't look like what your intuition might lead you to believe.
The difference in load between the exhaust stroke and the compression stroke at closed throttle is at the noise level. You're looking at the load delta of 10 psi times piston area compared to an inertia load of SEVERAL THOUSAND of pounds!
