C2 radiator support repair - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    The lower face of my radiator core support is rusted out. A repair piece is available. My question is; how do you remove the piece to be replaced? There appear to be numerous spot welds along the edge which will have to be cut or drilled out. Am I on the right track?
    Steve
    • 43221
    Re: C2 radiator support repair
    Steve-----
    Yes, you're on the right track. The old section has to be cut out at the welds and the new section properly aligned and welded back in.
      • 43221
      Steve-----
      • Bob R.
        • June 30, 2002
        • 1595
        They can be drilled out easily and the peices will come apart. I did discover after seperating the pieces that some of the rust was also in the upper frame. This required a little bit of sheetmetal work to correct.
        • Bob R.
          • June 30, 2002
          • 1595
