73 BB TEMP SEND UNIT - NCRS Discussion Boards
  • JAMES RICHARDSON
    How many wires got to the temp sending unit????
    Thanks James Richardson NCRS Member 73/bb/conv
  • Tom Freeman
    Re: 73 BB TEMP SEND UNIT
    Off hand I think it is just one, a green wire that has a heat protective jacket on it.
    tom...
      • 43243
      James and Tom-----
      Correct. It's just one green wire. However, the temperature sender grounds through the cylinder head. Make sure that you don't use any Teflon tape or sealer on the threads.
      • Gary S.
        • July 31, 1992
        • 1632
        Not to be confused with the TCS temp sending unit on the other side of the block. It takes two wires. Gary 21316
