C2 a/c heater vacuum switch - NCRS Discussion Boards
  • Bruce Boatner
    Does anyone know of a good source for the vacuum switch that mounts on the air distribution box of a factory a/c C2 (1964 in my case)? This is the switch that supplies vacuum to the heater control valve. A vacuum line runs from the intake manifold to the switch and another vacuum line goes from the switch to the heater control valve.
    I recently discovered that a prior owner removed the switch and spliced the vacuum two lines together. As a result, vacuum was continuously supplied to the heater control valve which allowed a continuous supply of hot water to the heater core regardless of the temperature knob position. Helped explain why I had always had warm air in the vents.
    Thanks!
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: C2 a/c heater vacuum switch
    You can do one of two things. Use a 70s plastic switch or get a repro. I think that Long Island Corvette has the repro.
    • Wayne W.
      • April 30, 1982
      • 3605
      • Bruce Boatner
        Wayne,
        Is the '70's plastic switch still available from GM?
        • Bruce Boatner
          Wayne,
          • Wayne W.
            • April 30, 1982
            • 3605
            Dont know for sure, but I think so. I got one a couple of years ago.
            • Wayne W.
              • April 30, 1982
              • 3605
              • Ronnie Robertson # 36786
                Corvette America has
                a repro that looks very much like the original.
                #33196 AC Heater Vac Switch. On Box Brass $62.00
                  • Page C.
                    • February 1, 1979
                    • 802
                    This Tip is worth $50 Bucks
                    The Good Dr. Rebuild's Catalog on page 55 tells you how to repair is brass vacuum switch
                    Hope this will help,
                    Page Campbell
                    • Page C.
                      • February 1, 1979
                      • 802
                      Page Campbell
                      • Randy S.
                        • January 1, 2003
                        • 586
                        Both Long Island Corvette and Corvette Central list the AC Heater vacuum switch at around $50.
                        Randy
                        • Randy S.
                          • January 1, 2003
                          • 586
                          Randy
                            I didn't have any luck with rebuild! *NM*
