1961 FI (Fuel Injection) Fuel Meter - NCRS Discussion Boards
  • Matthew Hirschler
    Hello,
    I am in a pickle; I have a hairline crack in the top of my fuel meter that I cannot figure out how to fix. Also, I have now managed--through extreme technical prowess--to strip a thread on said fuel meter...
    I am in dire need of a contact for replacement fuel meter parts; I live in Charlotte, NC, but will go to the ends of the earth to get this car working again.
    The car is a 283/275 HP; the engine is stamped early '61
    The ID numbers on the fuel meter are:
    TOP : 7014781
    SIDE: 252
    Any help is appreciated.
    Matthew Hirschler
  • William C.
    • May 31, 1975
    • 6037
    Re: 1961 FI (Fuel Injection) Fuel Meter
    Whee is the crack? The most usual place is the the cover at the fuel inlet. The fuelmeter cover is aluminum and can be welded. The damaged thered may be helicoiled, or filled with a good metal epoxy and drilled and retapped, depending on which one is stripped.
    Bill Clupper #618
    • William C.
      • May 31, 1975
      • 6037
      Bill Clupper #618
      • Matthew Hirschler
        On the top of the fuel meter, there is a 90 degree elbow that goes down into the meter from the fuel filter. when viewed from the passenger side of the car, there is a flat circular area (~3/4 in dia.). In between these two areas there is a ridge. The crack is between the elbow and the ridge, but moreso on the ridge itself; it runs side-to-side, not front-to-back.
        The thread is the most forward large screw (the third from the back, on the outside.
        • Matthew Hirschler
          • William C.
            • May 31, 1975
            • 6037
            Can you post a picture of tne crack, the thread is a relatively minor issue
            Bill Clupper #618
            • William C.
              • May 31, 1975
              • 6037
              Bill Clupper #618
              • Dennis C.
                NCRS Past Judging Chairman
                • January 1, 1984
                • 2409
                If the repair story has a sad ending, I believe this cover is available in reproduction.
                • Dennis C.
                  • January 1, 1984
                  • 2409
                  • DANNY PANTUSO
                    Hi Mattew, There David Skiados in Cary, North Carolina 27511 this guy is good David did my Top flight fuel injection unit on my 63 z06, His # is 919-4604669 . Danny Pantuso
                    • DANNY PANTUSO
                      • Jerry G.
                        • April 1, 1985
                        • 1022
                        Re: John Degregory has beautiful repo *NM*
                        • Jerry G.
                          • April 1, 1985
                          • 1022
                          • G B.
                            • December 1, 1974
                            • 1407
                            Fuel meter repair
                            Matthew, you sound like a confirmed do-it-ur-selfer, so I won't say anything about getting in over your head. We are all manly men here who can fix every single thing on our cars by ourselves, right?
                            First, remove the cover from the fuel meter carefully to avoid damaging the axle link or main diaphragm. Use your Dremel tool to deeply V-notch the crack. Use aluminum rod with your heli-arc welder to fill in the crack front-to-back. This will probably require completely sealing up the fuel inlet hole. After air cooling, grind down the excess weld material to expose the porosity pits. There will certainly be such pits because the cover is not made of pure aluminum. It has elements of zinc and trash it in that will form gas bubbles as you weld. Keep going back over it until the only porosity pits left are very small. Using the Dremel tool again, sculpt the outside surface back into the original contour. Use 400 grit sandpaper to leave a smooth finish. After drilling and re-tapping the fuel inlet hole, re-surface the diaphragm seat area on a pane of glass using 220 grit sandpaper lubed with WD-40. Give the cover a nice finish and a uniform color by putting it in a vibratory drum full of Mineral Spirits and small ceramic beads for about an hour.
                            As far as the stripped threads in the bowl, use your 10-32 heli-coil kit to repair that hole. Check the other screw holes for the upper fuel meter bracket closely. Some of them may be partially stripped too.
                            If you want to buy a reproduction fuel meter cover, get the one sold by John DeGregory. You can contact John by e-mail through his profile on this board or look up his phone number in his Driveline ad. Do NOT, under any circumstances, buy and try to use the soft reproduction cover made of pewter and sold by others.
                            • G B.
                              • December 1, 1974
                              • 1407
                              Fuel meter repair
