C2 Brake Noise - NCRS Discussion Boards
C2 Brake Noise
  • Stephen P.
    • September 30, 2002
    • 116
    C2 Brake Noise
    After replacing the right rear caliper line (worn through from rubbing against the shock), I have a fairly loud noise from the right rear that sounds like a vibration (not a squeal) when lightly applying the brakes. No noise when harder pressure is exerted. Have bled the brakes a couple of times using quick bleeders. Never made the noise before replacing the line. Replaced the pads thinking brake fluid may have contaminated them, but noise persists. I'm inclined to think I don't have all the air out of the system. Any ideas or suggestions would be appreciated.
  • William V.
    • December 1, 1988
    • 399
    • William V.
      • December 1, 1988
      • 399
