C2 Fuel Pump to Carb Line - NCRS Discussion Boards
  • Justin N.
    • February 1, 2004
    • 318
    Dear Members,
    I have a 67 327/300hp motor with the aluminum 350hp intake. Do I need to run the 350hp line from the pump also? I see that the part #'s in the Paragon catalog are different between 300hp-350hp. Thank you Much!
    Justin #41362
    • 43238
    Re: C2 Fuel Pump to Carb Line
    Justin-----
    If you want it to fit correctly, then you will need to use the L-79 pump-to-carb fuel line. The configuration of the 2 lines is slightly different to accomodate the increased height of the L-79 manifold. So, if you're using that manifold on a 300 hp, you need to use the L-79 fuel line, too.
      • 43238
      Justin-----
