paint stripping - NCRS Discussion Boards
paint stripping
  • David J.
    • April 30, 2004
    • 99
    paint stripping
    Hello everybody!
    My question is about stripping paint. I have talked to Halon Marking regarding there paint strip and they can not tell me if the materail will remove the primer.My car has the original paint job. Any suggestions?
    Thanks for all your input
    David
  • Len Rayca
    Re: paint stripping
    David: I have had good results using a paint stripper such as captain Lee's or Kleen Strip Fiberglass paint strippers. They remove the color coats of paint down to the primer. I then use a scotchbrite pad and laquer thinner to remove the primer which works very well. I flush well with clean water after each step and blow dry. The results are a silky smooth finish.
    • Len Rayca
      Re: paint stripping
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        Len - Think you've got it right. DC *NM*
        • Dennis C.
          • January 1, 1984
          • 2409
          • Timothy B.
            • January 1, 2004
            • 438
            Re: paint stripping
            Where can you buy Kleen Strip Fiberglass stripper???
            • Timothy B.
              • January 1, 2004
              • 438
              Re: paint stripping
              • Len Rayca
                Re: paint stripping
                Tim: I get it at an auto parts supply that also handles auto body repair supplies. You could probably also get it at a place that sells boating supplies since most of the newer boats are made of fiberglass. Len
                • Len Rayca
                  Re: paint stripping
