Exhaust pipe temporary fix - NCRS Discussion Boards
  • John Fulton
    exhaust pipe temporary fix john fulton my original mile lt has a hole in front of the muffler questions could anybody recommend a temporary fix i would rather drive it the last two months of the season and do a full replacement over the winter since this is an original car what would the members recommend i do for exhaust system replacement is there a preferred repo system thanks
  • Mark K.
    • July 31, 1995
    • 123
    Re: Exhaust pipe temporary fix
    re exhaust pipe temporary fix mark kane i had the exact problem with my mile lt last month i used a product called muffler bandage which i purchased at a local parts store to cover the hole until i found the correct parts if you check the archives you should find my old postings and the responses members provided the bottom line was that if one couldn't find an nos system walker made an excellent pipe and muffler for the car that was still available but the header pipe is out of production i was able to save my header pipe thanks to a skillful friend and a cutting torch most members told me to use allen's exhaust if i couldn't find the correct parts btw i saw an nos replacement system mufflers and pipes not welded together at carlisle for ouch
    Mark
    '70 Cortez Silver LS5 Coupe
    • Gary Schisler
      re exhaust pipe temporary fix gary schisler i also used the product muffler bandage make certain that you lightly sand and clean the pipe before you apply the product i bought some muffler putty to put in the small dime sized hole before i wrapped it with the bandage the putty hardens like cement btw both of these products are for short term use as you said you would doing gary
      • Tom Buddie
        In Front Of The Muffler
        in front of the muffler tom buddie if the hole is in front of the muffler where the pipe is welded then the bandage approach may not work because you have no way to wrap the bandage for a good mechanical repair the glue bandage may not adhere well enough if the weld is rotted then you should just replace the muffler if the weld is still good you can wire brush the crud off wipe down with lacquer thinnner for adhesion and apply jb weld epoxy if the hole is large fabricate a piece of metal to match the irregular hole plus overlap epoxy the metal patch on first after it sets up apply a second coat of jb weld i use tin snips and soda cans beer cans whatever i can dig up this is a temporary fix but it sure works for me as the need arises i've used the bandages also but only when i could wrap the hole
        • John Fulton
          Re: In Front Of The Muffler
          re in front of the muffler john fulton thanks for the info turns out the pipe in front of the muffler inches had completly rusted through i e it was just hanging there i found the bandage at the parts store but then noticed that they had exhaust pieces inches long got one of those and a couple of clamps and mended the two pieces back together another reply to this said they saw an nos system for guess i gotta make a tough decision this winter original my be great but for exhaust i dont know
