'57 Front and Rear Brake, Backing Plates - NCRS Discussion Boards
  • Bob A.
    • April 1, 2003
    • 172
    What was the original finish on the 1957 Brake Backing Plates? Bare metal, plated, painted, etc. What would be a good process to use in restoring original, rusty plates? Thanks for your valuable information, it's greatly appreciated.
    Bob
  • Mike M.
    • May 31, 1974
    • 8379
    Re: '57 Front and Rear Brake, Backing Plates
    i glassbead then paint black. mike
    • Mike M.
      • May 31, 1974
      • 8379
      • Bob A.
        • April 1, 2003
        • 172
        Mike:
        What was the original finish? If painted black, what sheen?
        Bob
        • Bob A.
          • April 1, 2003
          • 172
          Mike:
          Bob
          • Steve Junkersfeld
            Bob/Mike, An alternative to blasting that I like is to soak the backing plate (or any metal part) in a Phosphoric Acid solution. I use a 5 gallon pail. The Phosphoric Acid is available at most auto parts stores - the one I use is a PPG product. I like it because it distresses the metal less, is really pretty easy to do, and cleans the parts up just like brand new. It might be worth a try - just my 2 cents. By the way, after doing my chassis parts, I shoot them with Krylon satin black - it's a pretty good match. Steve
            • Steve Junkersfeld
              • Bob A.
                • April 1, 2003
                • 172
                Original finish?
                What was the original finish of the Backing Plate?
                Bob
                • Bob A.
                  • April 1, 2003
                  • 172
                  Original finish?
                  Bob
                  • Steve Junkersfeld
                    Re: Original finish?
                    Bob, My belief is that they were black (on my 56) - probably dip painted. Steve
                    • Steve Junkersfeld
                      • Bob A.
                        • April 1, 2003
                        • 172
                        Re: Brake Backing Plate, Finish/Sheen
                        If the Brake Backing Plate was originally black, what was the sheen?
                        Bob Adams
                        • Bob A.
                          • April 1, 2003
                          • 172
                          Bob Adams
                          • Bob A.
                            • April 1, 2003
                            • 172
                            Re: '57 Brake Backing Plate problem!
                            At the top of the rear Backing Plates there is a sub plate with two tabs (.5" wide x .25 thick, bent outward on a 45 degree angle) that straddle the ends of the wheel cylinder. One of these tabs are broken off on each of the rear Backing Plates. On the Right Rear Plate the Right tab is broken off, on the Left Rear Plate the Left tab is broken off. Nothing else is damaged and there are no signs of any wear on the Backing Plates.
                            Questions:
                            1. What could cause these tabs to be broken off? They are quite substantial!
                            2. What is the function of these tabs?
                            3. Is there any logical reason that these tabs would have been removed
                            intentionally?
                            I would like to fabricate two tabs and have them welded on.
                            3. Does this seem like a reasonable approach?
                            Bob Adams
                            • Bob A.
                              • April 1, 2003
                              • 172
                              Questions:
                              intentionally?
                              Bob Adams
