C1 - AC Fuel Filter - NCRS Discussion Boards
C1 - AC Fuel Filter
  • Jimmy J.
    • May 31, 1988
    • 304
    C1 - AC Fuel Filter
    What is the difference in an AC GF-124K and AC GF-124 fuel filter? Thanks in advance. Jimmy
    Re: C1 - AC Fuel Filter
    A shot in the dark is the 'K' suffix means it's a full filter kit vs. just the filter. Normally, you get a replacement filter and inner/outer rubber gasket. I suspect the 'kit' would package the filter, innner/outer gaskets, and the brass safety screen that virtually nobody knows about and/or replaces....
      • Dave S.
        • August 31, 1992
        • 2926
        Jimmy,
        From what I have seen yhe 124 and 124K are the same exact shape and configuration but for some reason the 124K seems to be more "red" in color. The 124 is more of a dark bronze. Either should work but a judge with a keen eye may deduct for the 124K.
        • Dave S.
          • August 31, 1992
          • 2926
          Jimmy,
          • Al C.
            • July 31, 1999
            • 274
            Jack - what and where is that brass safety screen? How fine a screen, where does it fit?
            I don't have one in either of two (repro) filter bowl sets.
            The only illustration in the ST-12 doesn't seem to show anything. What the ST-12 DOES show is a small washer-shaped seal going into the top casting first - and before finding this diagram I thought that part was a cushion for the bottom tightener! Oops.
            ... Al '58 245hp
            • Al C.
              • July 31, 1999
              • 274
              ... Al '58 245hp
              • Roy B.
                • February 1, 1975
                • 7044
                Jack I do remember a brass filter sreen in some gas filters , did the C1's have them ?? I think I do remember one in a C1 filter!( by the way they are all date coded inside like the 57 FI filter)
                • Roy B.
                  • February 1, 1975
                  • 7044
