1961 wiring - NCRS Discussion Boards
1961 wiring
    • December 1, 1999
    • 97
    1961 wiring
    I am about to make the connections between the rear harness and the dash harness. Has anyone used dialectric grease on the connectors to prevent corrosion? Is it worth while? TIA, John.
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Can't hurt, might help; I'd use it. DC *NM*
    • Dennis C.
      • January 1, 1984
      • 2409
      • Rick S.
        • January 1, 2003
        • 1203
        Re: 1961 wiring
        I installed a engine wiring harness from Letric Limited last year on my C2 and their instructions were to install dry, as shipped.
        Rick
        • Rick S.
          • January 1, 2003
          • 1203
          Re: 1961 wiring
          Rick
          • Mike M.
            • May 31, 1974
            • 8396
            Re: 1961 wiring
            agree 100% with dipstick. delco dialectric grease won't cure a continuity problem but its usage will prolong development of such problems. use it. mike
            • Mike M.
              • May 31, 1974
              • 8396
              Re: 1961 wiring
              • Christopher R.
                • March 31, 1975
                • 1599
                Re: 1961 wiring
                Yes. Use it. Good stuff. It'll help prevent corrosion at the connection. I use it all the time in electrical connections, especially on boats. 'Course this connection isn't in a real bad environment. So now it'll last 1000 years instead of only 500.
                • Christopher R.
                  • March 31, 1975
                  • 1599
                  Re: 1961 wiring
                    • December 1, 1999
                    • 97
                    Re: 1961 wiring
                    Thanks gents. Since I already have it, I will use it. John.
                      • December 1, 1999
                      • 97
                      Re: 1961 wiring
