correct valve cover bolts 69-L46 - NCRS Discussion Boards
  • Tom S.
    • March 1, 2004
    • 1087
    I bought a set of valve cover bolts to replace the incorrect ones I had.They have an m cast in them but the head seems very small.It takes a 3/8 socket. Is this the correct size?Also the way I understand it there is no washers under these bolts?Thanks in advance.
    Tom Stanton
    • 43221
    Re: correct valve cover bolts 69-L46
    Tom-----
    No, the original bolts were 1/4-20 size and used a standard, 7/16" across-the-flats wrench size. There were no washers under the original bolts. However, I recommend the use of them, anyway. Also, DO NOT OVERTIGHTEN these bolts.
      • 43221
      Tom-----
