engine stamp and body build date code - NCRS Discussion Boards
  • Joe 37510
    Hi Guys, is it possible for a car built in St. Louis to have the same exact date for the body build date and the date stamped on the engine pad? I always thought the engine date should precede the body build date.Both share the same date on this car. Is this possible? Thanks in advance...
  • Harry Sadlock
    Re: engine stamp and body build date code
    Good day. Joe, what year car? When you say "car built in St. Louis" are you referring to the final assembly when the car left the line or a body build date? Also, how did you determine the "build date" you reference. This will help answer the question.
    Harry
    38513
    • Harry Sadlock
      Harry
      38513
      • Joe 37510
        Hi Harry, It's a 63, and I'm told they were all St. Louis(none were A.O. Smith bodies for 63) The body build date code on the top left hand side of the trim tag reads J3, which is June 3. The engine stamp reads F0603... also June 3. This is what is confusing me. I thought the body build date always must come after the engine was built.This is where I'm hung up.
        • Joe 37510
          • dean petrucelli
            Joe
            The J3 does not refer to the 3rd of june but rather the 3rd week of June. Therefore, the body build could be any day within this 5 day window
            • dean petrucelli
              Joe
              • Harry Sadlock
                I agree with Dean.
                Harry
                • Harry Sadlock
                  I agree with Dean.
                  Harry
                  • Joe 37510
                    AHHH, This now makes sense! i thought the J3 equated to the 3rd of june. The 3rd week of June would make it all good. Thanks for your insight. I was banging mu head against the wall all night over this one.Thanks again to all who respomded... Joe
                    • Joe 37510
                      • Mike Cobine
                        Those '63 body builders had it easy. They only worked the first four or five days of the month.
                        • Mike Cobine
