66 electric window switch/connector - NCRS Discussion Boards
  • Steve Pettit
    My 66 convertible window stopped working. Opening up the console I discovered that the power supply line had come loose from its connector that attaches to the bottom of the window switch. I suppose that I need a new connector and that this can't be repaired, that may not be a valid supposition and if it is not please let me know. Is there a generic GM part # that may work, this looks like the camaro/firebird switch visually, but I don't have one to eyeball. Where can I get a new switch connector, would like it to be as correct as possible, but am not worried too much as this is a driver that is not shown.
    Thanks as always.
    Regards
    Steve
  • Steve Pettit
    Joe L
    Do you have part # for window switch?
    Steve
    • Steve Pettit
      Joe L
      Steve
        • 43221
        Re: Joe L
        Steve----
        Yes, I have a part number for the switch. It's GM #4434589. It's still available for a current GM list price of $50.72/each. However, I thought that what you were after was the connector. I'm not familiar enough with that particular connector to tell you if there is a GM piece available for that application. These sorts of connectors are not catalogued by specific application.
          • 43221
          Re: Joe L
          Steve----
          • Steve Pettit
            Thank you, Joe *NM*
            • Steve Pettit
              Thank you, Joe *NM*
