1980 Radiator: Re-core original or replace?? - NCRS Discussion Boards
  • David LaRussa
    If an 80 model radiator has multiple leaks, is it best to re-core the original or replace it with a new one? I have been told that Harrison is no longer producing radiators. What brand is preferred, closest to the original design, and where should I go to purchase such a unit?
    • 43240
    Re: 1980 Radiator: Re-core original or replace??
    David-----
    All of the radiators for 80-82 Corvettes are GM-discontinued. As far as I know, they are also discontinued through the Delco parts system.
    I think that having your radiator recored is the best option for you, at this time. This way you will keep your original tanks and end up with a like-new radiator from a functional standpoint.
    • David LaRussa
      Thanks Joe. I will pursue the re-core. Should an ID tag be attached to the radiator, and if so what part number for standard cooling?
        • 43240
        David----
        The 1980 standard radiator with both LG-4 (305) and L-48 (350) was GM #3053440. This number may or may not be on the radiator tag. Otherwise, there should be a tag with one of these broadcast codes: FF, FN, FP, FR
