Overheating Strategies (General) - NCRS Discussion Boards
  • Tony Roussos
    #31
    Re: Overheating Strategies (General)
    Ok.
    But, doesn't it run too fast to get hot, too?
      No. Heat is absorbed by the coolant, then transferred to the air by the radiator; when the rate of heat transfer to the air is exceeded by the rate of heat absorption by the coolant, temperature builds continuously and the system boils over. Aside from speeding warmup and ensuring a high enough coolant temperature in cold winter ambients so the heater works effectively, the thermostat's primary function is to modulate coolant flow to maintain a given temperature; the effective area of its flow opening is a carefully-chosen orifice that permits modulation within the flow rate of the opening. The thermostat has absolutely nothing to do with reducing abnormally-high operating temperature; when it's open, it's open. If you have a 180* thermostat and your system runs at 210*, replacing it with a 160* thermostat won't affect it one iota - it'll still run at 210* - that's a function of the radiator's heat rejection capability.
        • Tony Roussos
          #34
          WOW!!
          That's why I really like this organization!
          Thank you for the thermo-hydraulics lesson!!
          I always wondered what would happen if I took the thermostat out altogether. I just never got around to it.
          By the way, I was thinking of the furnace under my floor. I bought the tunnel insulation, then it occurred to me that the exhaust pipes radiate more heat than the transmission (4-speed.) So, I thought of having an aluminum plate made for each exhaust for my 71 like a catylitic converter shield. What are your thoughts on that one?!
          Thank you.
          Tony
          • Tony Roussos
            #35
            WOW!!
            Thank you.
            Tony
            • Robert C.
              • December 1, 1993
              • 1153
              #36
              Tony, I believe the exhaust heat shields are available, being a standard 63 Corvette item.
              • Robert C.
                • December 1, 1993
                • 1153
                #37
                • Tony Roussos
                  #38
                  Would they work on a 1971?
                  • Tony Roussos
                    #39
                    • Robert C.
                      • December 1, 1993
                      • 1153
                      #40
                      Re:heat shields
                      The standard shields should work, they clamp around the pipe. I believe 80s Corvettes have them also.
                      • Robert C.
                        • December 1, 1993
                        • 1153
                        #41
                        Re:heat shields
                        • Michael H.
                          • July 31, 1998
                          • 180
                          #42
                          I've seen so many Corvette owners get in fits because their car is running 210. Big Deal - more HP means more heat.
                          • Michael H.
                            • July 31, 1998
                            • 180
                            #43
                            • Tony Roussos
                              #44
                              Yeah, but, 210 at idle in traffic??!
                              • Tony Roussos
                                #45
