C1 / 57 / 997 Heads - NCRS Discussion Boards
C1 / 57 / 997 Heads
  • Joel M.
    • May 31, 1975
    • 141
    C1 / 57 / 997 Heads
    Can someone advise what chamber size one should be looking for on un-milled 57/997 heads? Thank you.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: C1 / 57 / 997 Heads
    1957 V-8 heads had a chamber volume of 55.7 cc according to NHRA specs but i could not find a 997 casting # listed
    • Clem Z.
      • January 1, 2006
      • 9427
      • Joel M.
        • May 31, 1975
        • 141
        Thanks Clem ------- Was pretty sure that 270 heads should be somewhere in 54/55 CC range but not certain. I think that the pass power pack and FI heads were maybe little larger CC (maybe 58/60) as plug hole was unshrouded a bit. Gonna CC a set of 270hp/997 heads today that don't appear to have been milled but not totally sure and would like to use CC results to determine.
        • Joel M.
          • May 31, 1975
          • 141
            997 heads had a (nominal) 55.6cc chamber.
