Engine ID - NCRS Discussion Boards
Engine ID
    Re: Engine ID
    The 1/8" NPT pipe plug was used at Flint Engine to plug a drilled oil gallery hole their machining process required; Tonawanda used a different machining process for the oil galleries which didn't require the intersecting hole drilled externally, so they don't have the hole or the plug.
      Re: Engine ID
      • Michael H.
        • January 29, 2008
        • 7477
        #18
        Re: Engine ID
        That's what I thought but I couldn't figure out why Flint needed it to complete the drilling for the passage but Tonawanda did not. There must have been several internal differences between the two castings. Thanks John....
        • Michael H.
          • January 29, 2008
          • 7477
          #19
          Re: Engine ID
          • Joe C.
            • August 31, 1999
            • 4598
            #20
            Re: Engine ID
            Mike:
            Yes, the Tonawanda 870 blocks had smaller casting numbers, and no pipe plug. They also had a 2 digit year code cast in, as opposed to the Saginaw (Flint) single digit year code. They were not used in Corvettes.
            Joe
            • Joe C.
              • August 31, 1999
              • 4598
              #21
              Re: Engine ID
              Mike:
              Joe
