chambered exhaust - NCRS Discussion Boards
chambered exhaust
  • Rick Hendel
    chambered exhaust
    I have a 1970 350-350 with stock exhaust which is very quiet. I love the mid-year sidepipe sound. Has anyone tried the under car chambered exhaust systems that claim side pipe sound. Thanks Rick
  • Warren F.
    • December 1, 1987
    • 1516
    Re: chambered exhaust
    Rick:
    I had a '69 Camaro with the chambered exhaust. The sound is terrific and deafening if used on a car with HIGH COMPRESSION. My car was a L78, so with 11 to 1, and being a solid lifter engine, the sound was awsome.
    Since you have a 11 to 1 motor as well, it should have an appealing resonance, although without a solid lifter cam, it may be a bit softer sounding.
    I've seen and heard chambered on lower compression engines and they sound like glass packs! Hope this helps with your decision making. Good luck.
    • Warren F.
      • December 1, 1987
      • 1516
      Rick:
      • Roger Legge
        One thing I have learned on this board is that exhaust sounds can vary quite a bit based on whether the mufflers or chambers are original GM pieces or repro parts, or even based on the company (design) making the repro parts. I can not say that I have heard what I know to be original GM sidepipes, or even an original GM Camaro undercar chambered setup. I have a '68 327/350 with an Allen's undercar chambered exhaust. I'm sure there are some differences in sound, but as far as I can tell it does have that 'chambered' sound.
        Roger
        #36316
        • Roger Legge
          Roger
          #36316
          • Donald O.
            • May 31, 1990
            • 1588
            I have a set on my 67 vert L79. I love 'em.
            If they're too loud, you're too old.
            Don
            • Donald O.
              • May 31, 1990
              • 1588
              Don
              • Ed D.
                • December 1, 2003
                • 207
                I have a set of Allens on my 1965 L-75 . Outstanding!
                • Ed D.
                  • December 1, 2003
                  • 207
                  • Jim T.
                    • March 1, 1993
                    • 5351
                    I have changed a the exhaust on my 70 to a 2 1/2 inch system and added a ZZ1 crate engine. Using mufflers I bought from one of the Corvette venders. It makes some noise, to me not unpleasant and really like the sound when driven agressively. Name of the mufflers are Pace I belive. Have had this set up for many years. The chambered exhaust systems I have seen on Corvettes seem to hang lower than the original systems underneath the differential.
                    • Jim T.
                      • March 1, 1993
                      • 5351
                      • Donald O.
                        • May 31, 1990
                        • 1588
                        My set from Allens fits just great. They are definitely NOT too low below the rear end and axels.
                        Don
                        • Donald O.
                          • May 31, 1990
                          • 1588
                          Don
                          • Randy Adams
                            On the Allens does anyone have a preference as to aluminized or stainless.
                            • Randy Adams
