1978 rear defogger relay - NCRS Discussion Boards
  • Craig D.
    • March 1, 2001
    • 98
    My rear defogger relay is trashed due to an old windshield leak.Located under dash on drivers side. Part # 527362, comes up obsolete (of course)...Anyone know if this is a Corvette only relay/timer or will another GM part interchange? I have not checked parts stores but thought this might be a dealer only item. Correct me if I'm wrong.Craig
    • 43221
    Re: 1978 rear defogger relay
    Craig-----
    GM #527362 is the part you need. It is discontinued. However, this relay is absolutely NOT a Corvette-specific item. It was used across all GM car lines for the rear defroster application. Mostly, its use was limited to 1978 models, but I think that they may also be found in some models a year or two each side of 1978.
    I don't know if this relay is available from aftermarket parts sources, or not.
      • 43221
      Craig-----
      • Craig D.
        • March 1, 2001
        • 98
        Thanks Joe.......... *NM*
        • Craig D.
          • March 1, 2001
          • 98
