C6 sightings - NCRS Discussion Boards
C6 sightings
  • Jeffrey S.
    • May 31, 1988
    • 1882
    C6 sightings
    I have seen several C6 Corvettes around the suburban Detroit area (a red one went past my house over the weekend and I stopped to look at a silver coupe #32 parked along Woodward today). They all had regular MI plates as opposed to manufacturer plates. The one parked alomg Woodward had a GM bar code decal on the windshield so I assume these cars must be executives cars since I was under the impression that they would not be available to the public until August or Sep. I was amazed to see how much smaller the C6 appeared than the C5's. I know it is indeed smaller but when seen on the road it looked MUCH smaller. Has any body else seen any on the road? What are your impressions?
    Jeff Salz
  • Tom D.
    • September 30, 1981
    • 2134
    Re: C6 sightings
    Jeff - I saw yellow. black and red near Royal Oak (all within one hour) on Friday night!
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Tom D.
      • 2134
      Re: C6 sightings
      Michigan Chapter
      Tom Dingman
      • Rick S.
        • January 1, 2003
        • 1203
        Re: C6 sightings
        Jeff/Tom,
        My former neighbor in Birmingham is an engineer for GM and has a silver coupe for 6 weeks and I met another engineer at 13/Woodward with a silver roadster and both were pre-production models used for evaluation by staff. I also have seen several others on the road. They are looking good!!!!
        Rick
        • Rick S.
          • January 1, 2003
          • 1203
          Re: C6 sightings
          Jeff/Tom,
          Rick
            • 15674
            Re: C6 sightings
            Haven't seen one on the road the the OA length is 174.6", which is 0.5" SHORTER than a C2. It's 4" wider than a C2, but an inch narrower than C5. Likewise it is an inch taller than C5 and an inch shorter than C2.
            Top speed in showroom stock trim is 300 KPH (186 MPH), and the EPA fuel mileage ratings are 19/28 with the manual transmission.
            What's really amazing is that the curb weight of 3179 pounds is less than 100 pounds heavier than the '63 C2 and actually marginally lighter than later C2 base small block models.
            When introduced as the model 901 in 1963 (later changed to 911 when Peugeot claimed trademark rights to three digit model names with a zero as the second number), Porsche's new model was about 2300 pounds. The current Corvette and 911 follow the same engine and chassis architecture of their forebears, but the base 911 is a thousand pounds heavier than it's 1963 ancestor and about 200 pounds heavier than a C6.
            I think Zora and every Corvette enthusiast can be very proud of GM's effort with the new C6.
              • 15674
              Re: C6 sightings
              • Clem Z.
                • January 1, 2006
                • 9427
                Re: C6 sightings
                GM sent one to DEI for the corvette show i was at over the weekend but dale jr like it so much he drove it to daytona for the nascar race so a bunch of corvette owners like myself did not get to see it. i saw the one at detroit auto show in jan but you could not get close up. mine is to be built the first week in aug. and i hope to have it for corvette carlisle. duke you should try and make carlisle as a lot of the guys you know will be there and the vetteheads put on quite a feed.
                • Clem Z.
                  • January 1, 2006
                  • 9427
                  Re: C6 sightings
                    • 15674
                    Carlisle - ...
                    isn't that about half-way around the world from Redondo Beach? Do I need a passport?
                      • 15674
                      Carlisle - ...
                      • Tom R.
                        • June 30, 1993
                        • 4099
                        Re: C6 sightings
                        They had em at Bloomington just across from C5 and you could visually see differences...more but, less real estate in front of front tire, and to the rear of the rear tire...nice and roomy on the inside. Actually is looked weird with the tires set at all four corners to the degree they were in contrast to the C5...but you knew it had more sticking power!
                        Tom Russo
                        78 SA NCRS 5 Star Bowtie
                        78 Pace Car L82 M21
                        00 MY/TR/Conv
                        • Tom R.
                          • June 30, 1993
                          • 4099
                          Re: C6 sightings
                          Tom Russo
                          78 Pace Car L82 M21
                          00 MY/TR/Conv
                          • Harmon C.
                            • August 31, 1994
                            • 3228
                            Re: C6 sightings
                            Jeff The PEP cars don't use manufacturer plates it was part of the securty thing a few years ago. My daughter is driving a black Intimidater this time and says she gets lots of NASCAR Earnhart questions at the gas pumps. If she comes back this weekend I think I will take it for a spin. Lyle
                            Lyle
                            • Harmon C.
                              • August 31, 1994
                              • 3228
                              Re: C6 sightings
                              Lyle
