'66 rear spring paint - NCRS Discussion Boards
  • Ian S.
    • June 30, 2002
    • 264
    Hi,
    My '66 rear leaf spring shows some of the original grey color and it seems to have a semi gloss look to it. The JG says it should be semi gloss grey but the Quanta grey that is being used to restore it is very flat. Any opinions on what is correct? Quanta says the product they sell is an exact match.
    Ian
    • 43222
    Re: '66 rear spring paint
    Ian-----
    The Quanta product should match perfectly since it's exactly the same stuff as was originally used on these springs.
      • 43222
      Ian-----
      • Tom D.
        • September 30, 1981
        • 2134
        Seminar in late July - rear spring details... *NM*
        https://MichiganNCRS.org
        Michigan Chapter
        Tom Dingman
        • Tom D.
          • 2134
          Michigan Chapter
          Tom Dingman
          • Chuck S.
            • April 1, 1992
            • 4668
            Ian, my 70 spring was flat gray.
            I had Quanta's spring paint, but didn't use it. It wasn't that the finish was too flat; I didn't think the color matched what was on the spring. I ended up using flat zinc-enriched primer because I thought it was a closer match to the greenish-gray was on the spring. Not only was the color closer, but it was the perfect application because it provides superior corrosion protection for the exposed spring, and no top coat was required (nothing sticks to zinc-enriched primer without pre-treatment). I can't explain why the color was not a match...maybe the flat finish attracted grease and road film that "changed" the color.
            • Chuck S.
              • April 1, 1992
              • 4668
                Re: Seminar in late July - rear spring details...
                The National Tech Seminar on rear springs (Franz Estereicher) has been replaced by an excellent seminar on Muncie/T-10 4-speed transmissions, by Morgan Chemello of MasterWorks Automotive; Franz had to cancel due to unforeseen business commitments in Venezuela scheduled at the same time as the National Convention.
                    • 11644
                    There's a pilot line car for sale in Venezuela?
                    PH
                      • 11644
                      PH
                        Only the Shadow knows.....
                            • 43222
                            Patrick-----
                            With the destination of Venezuela, I strongly suspect that the trip has something to do with something totally unrelated to a 1963 pilot line car OR, even, a Z-06. However, such a trip could have consequences which bode very well for the Corvette restoration hobby. I won't say more than that at this point, lest I start counting chickens before they hatch. I'll let Franz report as he thinks best.
                              • 43222
                              Patrick-----
