C1 Returns to the road - NCRS Discussion Boards
  • Dennis A.
    • April 30, 1999
    • 1010
    VIN # 10867S101127, a 1961, assembled in Oct. 1960, returned to the road, fully restored, after being in storage from 1993 to 1997. The engine started on the first try and after a quarter mile run, everything worked, except the lights. Next goes on the hood, get the lights to work and touch up as required... What a nice Fourth of July.
  • John M.
    • January 1, 1999
    • 1553
    Re: C1 Returns to the road
    Dennis,
    Congratulations on getting it back running, I know it has been a long and sometimes frustrating experience. It is all worth it however, when you can cruise down the road grinning from ear to ear!
    Regards, John McGraw
    • John M.
      • January 1, 1999
      • 1553
      Dennis,
      • Dennis A.
        • April 30, 1999
        • 1010
        Re: T.U. John
        If you have any short-cuts to where I might start looking for why the lights did not turn on...much would be appreciated. Radio, lighter clock & heater all worked. No head or tail lights?
        • Dennis A.
          • April 30, 1999
          • 1010
          Re: T.U. John
          • Doug Flaten
            Re: T.U. John
            I would suspect a bad connection or bad light switch. I think the light switch is the only common place where the wiring from both the headlights and tail lights meet. It could be a faulty breaker in the headlight switch, or you could have a short in either of those harnesses that is causing the switch's breaker to trip.
            You might pull the connection off and try to power up each headlight/tail light circut using an alligator clip or jumper to each of the spade connections in the harness. It would be a good idea to put an inline fuse on your jumper to make sure you don't fry the wiring harness in case there is a short in the harness. You might start with a 20 amp fuse. I forget what the headlights are rated at, but I think they are 55 watts each. 4 bulbs would pull a tad over 18 amps at 12 volts.
            Another possibility that occurred to me may be the dimmer switch. Check that it is not shorted.
            • Doug Flaten
              Re: T.U. John
              • Dennis A.
                • April 30, 1999
                • 1010
                Re: Thanks doug *NM*
                • Dennis A.
                  • April 30, 1999
                  • 1010
