Re: Need tips for cleaning underbody fiberglass - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2655
    Terry,
    A heat gun will work just fine to get the bulk of the undercoating off. Start on a low heat setting and move up gradually until you find the temperature that works the best. If you use a putty knife to scrape the udercoating off, be careful, it can marks on the underbody fiber glass. I would use a hard plastic bondo paddle if possible. It will not damage the underbody fiber glass surface.
    Then you can use bug and tar remover which I think is made by Turtle Wax. You could also use kerosene or 3M weather stripping adhesive remover. Get yourself some rubber gloves that will not be affected by the chemicals, I think nitrile rubber will not break down. I'd use medium to fine 3M scotch brite pads to remove the remaining undercoating. A tooth brush works well to get into the corners and small nooks & crannies.
    Hope this helps.
    Best Regards,
    James West
    Co-Chairman NCRS Nebraska Chapter
    Omaha, NE.
    NCRS member #18379
    1964 Corvette convertible
  • Terry F.
    • September 30, 1992
    • 2061
    James, I grew up on 49th and Grover. Now live in Washington state. Regards, Terry
    • Terry F.
      • 2061
      • Terry F.
        • 2061
        James, I tend to use a stiff blades putty knife with rounded edges. Works well in wheel wells where I will reapply an asfault based coating. If I remove it from some other surface and cause a scratch in the bare fiberglass, I have found that you can wet sand the scratches out with 800 grit. Best regards, Terry
        • Terry F.
          • 2061
