Oh, but I do. - NCRS Discussion Boards
Oh, but I do.
  • Mike Cobine
    Oh, but I do.
    Post it.
  • Michael H.
    • January 29, 2008
    • 7477
    Re: Ok, coming soon
    Mike,
    The first picture will be the car still under construction and the headers are quite visible. The 2nd shot is at the track so it's a little more difficult to see the configuration of the tubes. The OLD GEEZER in the engine pic is the very same race partner I had in the 60's and early 70's. We dug him up and put him back to work.
    • Michael H.
      • January 29, 2008
      • 7477
      Re: Ok, coming soon
      Mike,
      • Michael H.
        • January 29, 2008
        • 7477
        Re: GM BB headers *NM*
        • Michael H.
          • January 29, 2008
          • 7477
          • Mike Cobine
            Braidwood Nuclear Plant - I was there!
            Small world. I worked over at the training center in the summer of '85.
            Now on those headers, they don't look much different in the picture from the Hooker sidepipes I had on my '66. (Other that a couple of dents to clear the steerign box.)
            What is the difference of these vs the Hooker?
            • Mike Cobine
              • Michael H.
                • January 29, 2008
                • 7477
                (Message Deleted by Poster)
                • Michael H.
                  • January 29, 2008
                  • 7477
                  • Mike Cobine
                    Re: Ok, coming soon
                    Two things you probably already know:
                    Heat off the headers is tremendous. You are looking at roughly 1430 deg about 2 inches downstream from the port (about where the bend is). I see you have moved the brake lines over far, but I found it heats the master cylinder far too much. I helped it a lot with metal shield rolled in an "L" shape looking at the end placed about an inch under the MC between the headers and the MC.
                    Also, the heat of the steering box is terrible due to the proximity of the No. 1 tube. Another metal shield in there with an air gap helped. I also had a 2 inch duct that ran to that area to flush fresh air in to keep all this cooler.
                    • Mike Cobine
                      Re: Ok, coming soon
                      • Mike Cobine
                        Re: Left Side GM Headers
                        Looks real good.
                        Thanks.
                        • Mike Cobine
                          Looks real good.
                          Thanks.
                          • Michael H.
                            • January 29, 2008
                            • 7477
                            Re: Braidwood Nuclear Plant - I was there!
                            This was Dick, the electrical wizard. His wife worked at the nuc center in Braidwood. He wired all of my race cars since the early 60's. I've know him since I was about 14 years old. We went to reform school together.
                            I wound up installing Hooker headers on the car a few months after this but I don't remember exactly what the difference was but I do remember they were different. The GM header primary pipes were about eight or ten inches to long and the Hookers were a bit shorter. Brought the torque curve up a bit. I seem to remember different routing on a few of the primary pipes.
                            This car was fast! It was a dedicated restoration but with a "today" motor. Had the new style heads and that 6 digit GM cam. Made 697 HP on Dickie Kerchers dyno. This car was a LOT of fun to drive.
                            • Michael H.
                              • January 29, 2008
                              • 7477
