C2 windshield washer squirters - NCRS Discussion Boards
  • Jerry G.
    • April 1, 1985
    • 1022
    My original squirters that mount in the grill have a problem. The little brass balls won't rotate so it's tought to adjust the spot where the fluid squirts onto the windshield. I have soaked them in penetrating oil and heated them gently. Still no movement. Any tricks of the trade that you've had success with? jerry
  • Joe C.
    • August 31, 1999
    • 4598
    Re: C2 windshield washer squirters
    Hi Jerry:
    Are you sure that they are original type nozzles. You know that the reproduction nozzles are not adjustible.
    By the way, how did you fare with your PV last month. I hope that we were of some help with your washer pump, but there was no response.
    Best regards,
    Joe
    • Chuck G.
      • May 31, 1982
      • 2034
      If you have access to an ultrasonic cleaner, that might help. Ask you dentist. Most dental offices use one for cleaning equipment. Chuck
      • Gary S.
        • July 31, 1992
        • 1632
        I had a similar problem with my 66 and I solved it by using a dental pick, with the point gently inserted into the nozzle, to very carefully and gently persuade the nozzle to move. It was a trying time because I was afraid I would break the nozzle or the point off of the pick. Once I got it loose, I used a drop of oil on the ball and then moved it around. It was still working when I sold the car two years later, although it would sometimes require assistance from the dental pick.
        Gary
          My originals were stuck too, and I soaked them in PB Blaster for a couple of days until they responded to a pick.
          • Brian M.
            • February 1, 1997
            • 1839
            After reading this post and a similar one on the VH board I brushed mine with a brass brush and put a drop or 2 of PB Blaster on them, about an hour later I went at them with a dental pick and they moved with ease. Good luck.
