New Weather strp on 79 Vette T -Top tight - NCRS Discussion Boards
  • Tim Martin
    Any one know how to adjust T - Top height? After having new weather stripping installed, I now have a problem closing the lids. Does not seem to line up right for the rods to slide in. Afraid of breaking the lids. Can anyone please help..
  • Kelly Thomas
    Re: New Weather strp on 79 Vette T -Top tight
    Not sure about the 79 but on my 76 there is a latch with a screw on the end of the latch that can be moved in or out. Until the rubber gets a little relief I'd loosen that piece.
    Not sure if this is what you need without seeing. Hope it helps.
    Kelly T
    • Wayne P.
      • August 31, 1975
      • 1025
      The previous post will change the outside edge a little. The inside is changed by adding or removing shims from under the little chrome pieces that slide into the center "T" bar.
