C-5 NCM build sheet timeline - NCRS Discussion Boards
  • Glenn Ochs
    I am looking at a C-5 convertible but I want to confirm the original equipment. The owner has nothing to offer other than the obvious. If I order a buildsheet on-line from the National Corvette Museum how long does it take to receive? Is there a way to see the buildsheet (once purchased), via e-mail just to confirm the equipment? Thank you in advance for your assistance. Glenn
    • 11651
    Re: C-5 NCM build sheet timeline
    I'm not at all sure how long it will take to get one, but realize that there's a sticker with the options right on the car. I know C4's had it inside the center console cover; I'm not near the C5 to tell you where it is on those (glovebox? rear compartment?). Someone else will likely chime in.
    Did you look already?
    Patrick
    • Glenn Ochs
      Hi...If someone could point out where the option list/sticker is applied on a C5, it would be appreciated. This is likely all I need right now. Ignore the time, had an extended snooze(old age). Thanks again... Glenn
      • Chuck G.
        • May 31, 1982
        • 2034
        My wife and I just bought a "new", to us, 2000 yellow roadster. The build codes are on the inside of the glove box door....that's the glove box on the passengers dashboard....NOT the center console. My old 88 and 92 had the sticker under the center console lid. Hope this helps. Chuck
