C2-Rear Leaf Spring - NCRS Discussion Boards
C2-Rear Leaf Spring
  • john lokay
    C2-Rear Leaf Spring
    The original rear leaf spring from my L72 needs to be re-arched. Who does this type of work and will the re-arched leaf spring perform like new? Also, How can I tell if my spring is the heavy duty F41 type?
  • Gary B.
    • February 1, 1997
    • 7028
    C2-Rear Leaf Spring
    John,
    One company that I've read that does re-arching correctly is Eaton-Detroit Spring. Give Mike Eaton a call if you have any questions about re-arching. Regarding the heavy duty question, what year is your car and how many leaves does the spring have?
    Gary
    • john lokay
      Re: C2-Rear Leaf Spring
      Gary,
      The car is a 66 coupe and I have to check on the # of leafs. I have a replacement spring on the car now and its lousy as the car bounces around "like a cork" in the ocean. BTW, great article that you and Joe had in the recent issue of the "restorer". Also, do you have a phone # for Eaton Detroit?
      • Gary B.
        • February 1, 1997
        • 7028
        C2-Rear Leaf Spring
        John,
        Is your original spring a two-stage or a one-stage spring? If it's a two-stage spring (3 shortest leaves are not arched), then you have the standard spring. If it's one-stage (all leaves arched), then it should be the HD spring.
        You can contact Mike Eaton at:
        1555 Michigan
        Detroit, MI 48216
        Phone 1-313-963-3839
        Please tell him you read my article and I gave you his name.
        Gary
