pitman/third arm ball wear - NCRS Discussion Boards
  • Chris H.
    • April 30, 1990
    • 817
    Where can I find allowable wear on the ball? Not in service guides that I can find.
    Pitman ball has an oval delta of .016", Third arm is .034". I did find one mention in the archives that .075 was too much.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: pitman/third arm ball wear
    The wear is OK check the ball cups for wear and replace them (same as any early car) Some one may have tightened the adjustment to much or didn't grease them often.
