Well Duke I went and did it - NCRS Discussion Boards
  • Chuck R.
    • April 30, 1999
    • 1434
    I picked up a like new set of 5 GoodYear "Integrety" 225/70/15 tires for my project "Mind Bender".
    Picked them all up at a local law enforcement auction for $100.00
    Man, talk about rubber on the road, these tires are brutes!
    Now please tell me they will fit my AGs and also fit into the spare tire tub.
    Any history on this tire good or bad?
    Chuck 32205
    • 15643
    Re: Well Duke I went and did it
    What's the service description and UTQG rating? For what year Corvette?
    • Chuck R.
      • April 30, 1999
      • 1434
      Re: Her's what I've found
      in order as depicted on the side wall
      E0LR
      DOT PDUU
      1MHR
      0300
      Tread wear "460"
      Traction "A"
      Temperature "B"
      Whoops, sorry Duke, I have a 68 small block. It WOULD help knowing that wouldn't it
      Thanks for your assisstance,
      Chuck 32205
        • 15643
        The service description is located just after the size designation and consists of a two or three digit number that is the load index followed by a letter to indicate the speed rating, if it's a speed rated tire. You need a table to convert the load index code to actual load, but this data is also placarded on the tire.
        A treadwear rating of 460 is a fairly hard compound and a temperature rating of "B" would indicate a speed rating of no higher than "T" and probably "S"
        Overall these are so-so tires, definitely not high performance.
        Goodyear's police pursuit tire is the Eagle RSA in either 225/70R-15 or 235/70R-15. The service descriptions are 100V and 102V for the 225 and 235 respectively, and both carry a UTQG rating of 260wear, A traction, and A terperature.
        The closest match in revs per mile to the OE F70-15 is 215/70R-15, but I recommend the 225/70R-15 for all Sharks since they all have enough wheel width for this size, including the 7-inch Rallys on '68. If anything the speedo will likely be more accurate as the F70s were a little less in revs per mile than the earlier 6.70-15 cars, and the speedo gearing did not change.
        The F70-15 and 215/70R-15 are speced at 775 revs/mile, the 6.70-15 and 225/70R-15 at 760 revs/mile - about a two percent difference. When the tires wear down to the wear bars the revs/mile will increase about two percent.
        • Chuck R.
          • April 30, 1999
          • 1434
          Re: Thanks Duke
          I appreciate your patience with me in working through this amazingly very involved and in-depth process.
          As I'm not going to be running any road courses anytime soon I think that they will quite sufficiently do the job until I can swing an up-grade.
          Thanks again Duke,
          Chuck 32205
          • Chuck R.
            • April 30, 1999
            • 1434
            After the tire size derivitives it has 100S
            Thanks again Duke,
            Chuck
